| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Just wanted to find out if the rear axle on a torque tube was located below or above the rear springs? I've tracked an issue with the steering to the castor change caused by the open driveline/rearend swap? Thanks,
| | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | My axle is above. 1953 3100 torque tube, stock.
Joe
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I kind of thought that was how it was set up, but couldn't remember. I've seen pics with the axle under the spring, but maybe it was a 3/4 ton? I'll keep working on the castor issue. Thanks again. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | 3/4 ton has rear axle under the springs. 3/4 ton also has front caster shims that have a larger angle than the 3100 shims (if you're looking for more caster).
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | |
