| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 155 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 155 | Well This 63 has been Ours for almost 2 weeks I have enjoyed finding some of the "fixes" it has suffered over the years,, the one I find most puzzling is the lamp cord used to connect the ignition circuit to the POS. battery terminal,, It runs from the battery down and across the front grill. I am looking for the "right way" to fix this,, Thanks
I have a 55 second gen!,, work in progress 1963 long bed step side driver Just a guy who digs old trucks! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "The ignition circuit" covers a lot of things. What exactly do you want to know. I have a 1963 manual with schematic/wiring diagram. If you are planning on keeping this truck then you need the manual.In the mean time, I will try and help. Give a little more info to your question and state what your experience with wiring is. I understand that you want replace the lamp wiring. Can you just replace with auto wire?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | This site linked below has the wiring diagrams. However, it sounds like you are looking for the wire routing which may be in the manual linked above. Wiring
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
