3 members (Gdads51, Hotrod Lincoln, 1 invisible), 115 guests, and 0 robots.
Topics128,039
Posts1,055,591
I was working on the fuse box Sunday with a Dremel & a tiny wire wheel. It is cleaning up nicely and I'm going to paint the metal bits with an aluminum paint that will look something like the original plating. In the contact areas the plating was still mostly intact and I'll leave those clean and unpainted.
The fuse box & other parts have little clips that are tightened with a screw down on top of the fork from the harness. While holding one of these with a pair of needle nosed pliers the little wheel grabbed it and launched into orbit. I can get another one from the now discarded regulator but I think I would rather have a set of new plated ones. Looking on the Classic Parts site I saw nothing. Any ideas where I can get a small quantity of these?
Vintage Paul
Paul O'Neil, SoCal
1951 Chevy 3600 Project
Sir Searchalot
Sir Searchalot
It would be nice to post a picture. It's not difficult now. Is it this type of clip? I know this is a junction block but am trying to identify the "clips". Is it a combination fuse holder and screw terminal?
Also, don't use fork tongue wire end terminals unless you can't get the screw out. Use ring tongue terminals.
Not quite the same. The ones I'm wanting have a little tit sticking down into a hole for location rather than using the sides of the base. I believe GM would have used these on the regulator & other items as well. They will need replacing or refinishing to use them again.
I would LOVE to post pictures. I have a digital camera and shoot pics all the time. As I understand it this forum needs third party hosting which I baulked at. Is there another way?
Vintage Paul
Paul O'Neil, SoCal
Sir Searchalot
Sir Searchalot
The picture posting has changed. You can post directly from your picture files. Reduce the subject pics size to 300K or less and click on edit and then on "attachment manager" at lower left of the post. Easy.
Outside Hosting can never be trusted again IMO.
Light switch may have the same things you are looking for.
"Use Full Editor" to post a photo/picture/image (lower right command under "Quick Reply" box)
Yes, the light switch, the Hi Bean switch and regulator should all use these little clips. We all need'em and I'll bet somebody sells them by the bag. I'm not sure what name to use searching for them
Here is a trial picture showing recent work:
Vintage Paul
Paul O'Neil, SoCal
It worked! How bout that!
Vintage Paul
Paul O'Neil, SoCal
Sir Searchalot
Sir Searchalot
Earth calling Paul and Carl................ come in Paul and Carl................can you post a picture of the clips............over.
We are your friends, we mean no harm. We seek only friendship. We are the ones who sent ET home........over.
You would make me get up in the middle of the night and brave the cold to go out
to the barn and snap a picture, wouldn't you Paul!!!!
http://www.pbase.com/dennygraham/image/166707210/large
I've never seen any vendor that carries these as individual items. You would
have to scrounge one from an old regulator.
67 years with a forked tongue Bart and........still attached.
Denny G
Denny G
Sandwich, IL
Eeeweeeeeohwohwhooopistpist beep whewwheeew beep beep beep interplanetary comm path established - come in earthling Bartamos - we received your request for a pic and have complied. Sending now on protocol Alpha-Tango-Zulu 4599234Romeo. Are you recieveing? Phishst wuwuwu-pist OVER.
WARNING - Emperator DROF of the planet Mopar is going to steal all the old GM trucks on planet Earth and convert them to interstellar battle cruisers. Send us your electrical clips to make defensive weapons . . .
OUT
Vintage Paul
Paul O'Neil, SoCal
Sir Searchalot
Sir Searchalot
They serve no purpose whatsoever. Jettison them. Use ring tongue terminals on ends of wires and screw them on. The cover hides the "non original" fear. Problem solved and with a more secure, reliable, safe and modern termination..... BEEP...... BEEP.....beep...... ### ##
I'd still like to have the original style if I can find them. The new harness has the little forks on it now.
Anybody have a source?
Vintage Paul
Paul O'Neil, SoCal
"think outside da box" - would be real easy to fabricate replacements indistinguishable from the originals
Sir Searchalot
Sir Searchalot
Yes you can recycle some sheet copper from something and, with metal shears, cut and bend. But wanting an original piece inside a box does not compute in the Milky Way Galaxy.
Ring tongue terminals can not come loose. Forks can. Original does not apply. You better be building one of them Can'o'Coors d'elegance trucks if you are worried about correct terminal clamps.
As reliable, it is not. Strange thinkers, these people are.
Those (pictured in Paul's post) are the same as what is on the light switch (as stated previously).
