4 members (Charles in CA, IHPWR, Otto Skorzeny, 1955 1 Series), 155 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
On my 69 c40 I was going to cut frame and put truck bed on. What's the best year/style bed to use for this. Thanks
Big Bolt Forum Moderator
welcome to the site! Please give a little more info, what is on the truck now? (flatbed, no bed, box?) What type of bed are you wanting to put on it? Are you looking to make a heavy duty pickup?
Mike
It's a flat bed now. I just want to fab a pickup bed on it.
Crusing in the Passing Lane
What is your intended use?
Ed
Just driving around neiborhood, no work
you might find a stepside bed of the same vintage and stretch/modify as needed. The stepside beds did not change a ton as far as basic looks go for a number of years.
Mike
I think noting would look better then a flatbed on 1.5 ton truck.
If the truck is a SWB model then the truck is not that large to
start with.
If the truck has the LWB, you can shorten the flatbed.
Either way, you then can make a set of low side racks and that
truck will look sharp.
Too me putting a pickup bed on a 1.5 ton just will not look
right, no matter how well the metal work is done, because
the proportions will be off to what the truck was originally
designed.
To me most custom work always looks off because people
make changes and additions that clash with the original
design instead of fitting in with it.
Just because a striped suit, and a plaid shirt, with a polka dot
tie all individually look good does not make them all go
together to wear at the same time.
Jeffrey
Insomniac
Insomniac
Similar to this?
C50 Pickup
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
So I guess it CAN be done. Not sure if I would do it, although those don't look that bad.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I wonder what the ride is like, unless they changed to air in the rear and removed some leaves in the front?
Ed
Modified Stake bed on my 42 1.5 ton Chevy. Shortened it and narrowed it then built a simple step rail for it. Not hauling anything in it just like the look
