6 members (1955 1 Series, Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl), 110 guests, and 3 robots.
Topics128,087
Posts1,056,119
Members48,435
#12465 10/02/2003 9:12 PM
First. Thanks for the answers I received for my other question. I am looking into a few of the options. Much appreciated. Now for my next question. I've got a 77 GMC 1/2 ton and a 49 GMC 1/2 ton. From all the reading I've been doing I know I've got huck brakes for my 49. They came in a few buckets so I don't even know if all the parts are there. There's new cylinders, drums and shoes. I tried do do a search to see if I could find some pictures of the huck system but came up empty. I've read that the huck system has a few downsides. What I'd like to know is can I take the whole braking system from my 77 GMC 1/2 ton and put it on my 49? Or should I buy conversion kits for the front and back instead. I am going to take off the cover for the rear end and count the teeth to see what gear ratio I have. If it's okay I will leave that rearend in there for now. I am looking at putting a 305 into the truck soon. My main objective is to have a safer truck so my kids can drive it. Got a daughter that just turned 16 and she's anxious to get behind the wheel with her friends.
#12466 10/02/2003 9:59 PM
The only brakes that fit without serious modifications are the originals, or the 1951-54 Bendix, or the 50-54 car, but the cars only have 5 lugs.
Paint & Body Shop moderator
#12467 10/02/2003 11:29 PM
Thanks 4ontheFloor,
Even the disc conversion kits need serious modifications? I guess I need to find an old 51 to 54 donor truck then hey...
kskt4
#12468 10/03/2003 2:17 AM
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#12469 10/03/2003 5:10 PM
kskt4 I think you can buy Braketes that will let you adapt to disc brakes. You will need to use the chevy 4X4 rotors and calipers, which may or may not be the same calipers that you have on the GMC. Buffalo is the company name that makes the brackets. I think they have a link in the link section.
There is more to it then just this but you get the idea and if not email me and I will tell you more
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#12470 10/03/2003 6:56 PM
The disk brake kits should come with all the brackets and hardware you need, but you will also need to fabricate a new master cylinder mount and run new lines. Its not really trivial, but it is a good modification if there was one.
