2 members (BC59, Danielbolt), 210 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
I got a rebuilt water pump for my 51 from a fellow stovebolter and I notice it doesn’t have the metal backing plate my old pump has. I have tried getting the old one off but it appears to be unremoveable due to the two big screws being impossibe to remove without damaging. Is this something I can buy or do I have to salvage this one?
Thanks, Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Heat and penetrating oil should loosen those screws. If you can find an impact driver with a bit that's a close fit to the screw heads, that should work, also.
Thanks Mr. Jerry, I guess I will keep trying. Good to hear from you sir smile
Troy
Troy
1963 Chevy C60
Big Red Chevy
