0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | I got a rebuilt water pump for my 51 from a fellow stovebolter and I notice it doesn’t have the metal backing plate my old pump has. I have tried getting the old one off but it appears to be unremoveable due to the two big screws being impossibe to remove without damaging. Is this something I can buy or do I have to salvage this one?
Thanks, Troy | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Heat and penetrating oil should loosen those screws. If you can find an impact driver with a bit that's a close fit to the screw heads, that should work, also. Jerry
| | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Thanks Mr. Jerry, I guess I will keep trying. Good to hear from you sir  Troy | | |
