6 members (Hotrod Lincoln, Christian, baldeagle, Wickedbass, NJC, 1955 1 Series), 57 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#1246496 12/11/2017 2:39 PM
My 1955 series 2 has a Cream Medium interior paint with a black dash top. The outside paint is a light blue. From the factory What other exterior colors went with the cream interior? That's assuming this was the factory color. I am initially looking at a darker blue than it is, but could go with some other original color except juniper green.
1961 ford f500
1953 3100 five window (https://www.facebook.com/1953-Chevrolet-5-window-1533405913413610/)
1955-2 3200 big window (https://www.facebook.com/Leep3200/)
55yrs as a mechanic and retired. (kind of)
LeeP #1246501 12/11/2017 3:11 PM
LeeP,
This information from the 55-2nd Specifications Manual is no help?
This 1956 paint sheet says these colors are mostly "repeats" from 1955 (Task Force).
I have a 55-2nd Salesman Truck Data Book that might have interior color information. I'll and post any info here.
Good luck,
LeeP #1246505 12/11/2017 3:38 PM
Thanks tclederman
Seems every color board has different colors and they rarely mention 1955 truck. Looking at those, I could have a beige color inside. It doesn't look like a repaint and the sheet I have only mentions Cream Medium or Yukon Yellow for 1955. That's my choices so far for the color that mine is.
1961 ford f500
LeeP #1246506 12/11/2017 3:47 PM
I have three different 1955-2nd Task Force Truck Data Books. In the paint chips sections, the exterior color names (but not necessarily the actual "colors"/hues) changed a little between April 2 1955 and August 22 1955 and November 15 1955.
Interior paint chips/names are not provided. I'll look in the cab/interior section of the books.
LeeP #1246513 12/11/2017 4:18 PM
De Luxe Cab Compartment/interior - Havana Beige is specifically listed
I cannot find the name of the standard interior cab color (might be Bombay Ivory as used on the exterior?)
Cream Medium is listed as an exterior color.
In 1956, Bombay Ivory was gone - replaced by Arabian Ivory
LeeP #1246576 12/12/2017 12:57 AM
So Havana Beige it probably is, I will try to get some touch up paint and see.
1961 ford f500
LeeP #1246577 12/12/2017 1:02 AM
Where did you find Havana Beige, LeeP?
From your post. I was also looking for the interior color. If its not the cream because its listed as an exterior color according to your post.
1961 ford f500
LeeP #1246588 12/12/2017 2:09 AM
I do not know what was the interior color for standard cabs.
It is not listed in any of the three different 1955 Task Force Truck Data Books that I have.
The only named/listed interior color was for the De Luxe Cab Compartment/Interior RPO (Regular Production Option).
LeeP #1246598 12/12/2017 3:10 AM
Ok, so lets try this. In the pictures above, what colors do you think they are? I am looking for the original color blue that would be darker than the one shown if there is one. I am pretty sure that the outside of the truck has been painted, and now not so sure the interior hasn't been painted.
1961 ford f500
LeeP #1246602 12/12/2017 3:49 AM
the Havana Beige in Leep photo is just like my 55 one ton. It was easy to match at the local hardware store.
I just brushed it on quite wet and it flowed out well. About 20% of the interior did not need painting and I defy you to
find the new fresh rather than the 62 year old paint.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
LeeP #1246803 12/14/2017 12:17 AM
This is why there is confusion on my part, the colors mentioned and the charts available do not mach up to the colors mentioned for 1955 in most cases.
1961 ford f500
LeeP #1246806 12/14/2017 12:48 AM
LeeP #1246826 12/14/2017 2:44 AM
Ok, you got me there TC. What color is empire blue and Crystal blue? Which one is darker?
1961 ford f500
LeeP #1246828 12/14/2017 3:04 AM
These are terrible quality chips.
Crystal Blue is lighter.
I'll look on my 1955 Truck Data Books tomorrow - please send me a PM, if I forget to reply.
LeeP #1246830 12/14/2017 3:06 AM
http://paintref.com/cgi-bin/colorco...moy&year=1956&page=1&rows=50
click the color/image in the "sample" column for each color
good luck - Crystal Blue is lighter
