| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 36 | I'm getting ready to swap in a 350 gen1 engine and T5 transmission into a 56 3100. I currently have a 283 and a Muncie 3 speed. I plan on using the same bell housing attached to the 283 not sure what type of starter to use. My guess is I have to use the old style 3 bolt starter that bolts to the bell housing and not the 2 bolt that bolts to the block. Is there a mini starter that will work for this engine combination. Also putting a new flywheel and clutch etc in it. Anything special need to know about that , other than a 168t flywheel and early throw out bearing? Thanks Charles | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Use your existing bell housing, release arm & bearing, and 3 bolt starter. Replacement flywheel (168t) should be for an 11" clutch. The T5 likely uses a different clutch disc. Not sure about a mini starter with that combination as they mount to the block instead of the bell housing. Fred
| | | | | Joined: Sep 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 36 | Thanks, pretty much what I was thinking, but would be nice to be able to use a mini starter. Going to change the input shaft to the 10 spline Jeep. Charles | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | When I used a cast iron Chevy V8 bellhousing on my engine dyno, we had to cut part of the the corner off of it that mounted the 3-bolt starter to make a block-mount starter fit. The aluminum bell housing with the built-in starter clearance didn't look sturdy enough to handle the torque load the dyno was capable of exerting on the housing. Jerry
