5 members (TUTS 59, Gdads51, massey1951, JW51, sron48), 92 guests, and 2 robots.
Topics128,038
Posts1,055,583
#1246502 12/11/2017 3:11 PM
About a 1960 261 engine according to the cast numbers. The carb has me a bit baffled. Carter carb 1.75 interior measurement across bottom opening . Should be a 261 carb at that measurement. The vacuum hole on the base of the carb looks to be in the correct area for a 235 and centered on the wall of the carb at about the 10 o’clock position. Also below the base of the carb was a steel plate in the shape of the base gasket only squared off on one corner. 1/8 “ thick. No hole for the vacuum hole on the carb base on this plate. Base gasket was a 261 gasket. The one with the four notches. The notches on the gasket doesn’t line up with the vacuum hole on the base of the carb. What do I have here? Should not the gasket at least allow for the vacuum hole ? Thanks
can216 #1246504 12/11/2017 3:34 PM
J Online: Content
Rochester made a B specific to the 261. Carter had a YF model # for a 261...but never actually produced it (according to some info carbking has posted here).
Are you sure your carb is a carter? Posting some pictures would help if you can.
1951 3100
can216 #1246520 12/11/2017 5:18 PM
Yes you are correct. Rochester make in us patent pending as it reads. Sorry a bit dirty. I guess my questions are not so much for the carb but the carb base which bolts above the insolator. And i got to start posting pics thanks
can216 #1246540 12/11/2017 9:14 PM
Update . After a new set of plugs she started right up.one bad plug wire and numerous dead plugs. She started up but no idle.just ran on choke. After fixing a vacumn leak she idles like a champ and starts easily.
can216 #1246543 12/11/2017 9:56 PM
Carburetion specialist
Isn't it amazing how a good electrical tune-up will solve a "carburetor" problem? wink
Glad you found the solution.
Jon.
The Carburetor Shop
