0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1246110 12/08/2017 12:30 AM
Building a bead roller and need to get a feel for the speed of the powered feed roller.
My angle drive runs from 0 to 4,000 and is reversible. So I need any info on the speed
of your powered bead roller, it's motor and the pulley or sprocket reduction or gear reduction.
I just know someone out there has an Eastwood, or Mittler Bros or Bailey roller.
Tks
dg
Denny G
Sandwich, IL
DG;
I did a quick google search and found this video showing a pulley arrangement on a diy powered bead roller (there are a bunch more on YT). I would think that you will need a variable speed control. In my search I saw mention of treadmill motors, sewing machine motors and a few surpluscenter gear drive motors.
DIY Variable Speed Bead roller
SimS
Worked it out over night Sim. Had an old original Bridgeport X-axis power drive I've been
keeping for a few decades. 1/2 hp, variable speed from 0 to 145 rpm and reversible. Set
it up on the bench this afternoon and checked it out using a Central Electric foot switch.
Works as good as Lazzie's bead rollers. Found an assortment box of Lovejoy flexible
couplings I picked up at a garage sale many years ago and I'm going to direct drive it
to the lower shaft. Also gonna make up a set of adapters for the business end of the
shafts so I can fine tune the center lines of the rollers.
http://www.pbase.com/dennygraham/image/166690043
Hung the gear motor when I was thinking about using a chain drive. Now I'm gonna
go direct with the coupling.
Denny G
Sandwich, IL
Moderated by  MNSmith
