2 members (Cletus1950, 1955 1 Series), 68 guests, and 5 robots.
Topics128,172
Posts1,057,105
Members48,463
#1246050 12/07/2017 3:01 AM
I just found 2-gal of DuPont URO 1140 Primer Filler in a box on the shelf from a project we started 20 years ago. There is a gallon of Convertor and a quart of Activator also in the box. Is this stuff still any good? The paint still shakes/moves in the un-opened cans...
If it's OK to use, is it compattable with new top coat paints?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It may be good, may be not. But it would suck to have to strip it all off. I once used a can of epoxy primer that had been opened 6 months earlier, then re-sealed. It never would cure totally. The supplier said it was because it had a limited shelf life after opening. It was really a pain to take it all back off.
Nowadays I spray a test patch and see how it goes. I recently painted my wheels with a 20-year-old can of acrylic enamel when a test spray showed it performed like new.
