3 members (cmayna, tclederman, 1 invisible), 121 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
1958 235 Chevy.
I just got done doing the timing cover lower bolt conversion and then test fit it to the plate and block. I noticed that three of the bolts/screws for the cover, when tightened down will push the timing plate away from the block and will then cause a leak. I removed the cover and plate and found it to be three of the bolts, that behind them is just a small "dimple" behind the plate into the block. The bolts that actually thread into the block do not cause this issue. Has anyone else had this problem? If so what was your solution? I'm using only 1/4" bolts with one lock washer. I know I could just stack some more washers, but would like to keep it uniform. Suggestions?
58' 3200 235 3-speed/OD
Why not just file or grind a couple of threads off the bolts that are bottoming out?
There are different lengths of bolts used on the timing cover and you need to sort that out. I can't imagine being able to bend the front plate with one of those small bolts and limited thread. There are some bolts that go right through the plate in an area where there is no block behind. If too long a bolt is used there it will give you grief later in the engine compartment.
1951 1 Ton Completed
@Hotrod- That should work, only issue may be safely doing so with what I have available to me.
@truckernix- From what I have seen there are only two lengths of bolts. The longer two on the bottom that go through the main cap into the cover and then eight shorter, 1/4", ones. When I tighten up the one that do not thread into the block, but just have the dimple behind the plate, they push the plate away from the block, but don't bend it permanently.
Do you have a vise and a file? Clamp the bolt head in the vise with the threads pointing up and take a few file strokes at a time off the end of the bolt until it's the right length. Time-consuming, but safe and accurate!
That would be the safe route. I was thinking of using the grinder with the flapper wheel. But I wanna keep all my digits.
1 Offline
Spin a nut on the bolt, then grind away, bevel it a bit , then remove nut. Now use bolt. Its not real complicated rocket science.
I tightened up the bolts in my bench vice and ground away. Then ran my tap over them to clean them up. Work fine now without pushing the timing plate away from the block.
That bench vise was one of the best tools I every bought!
