5 members (Peggy M, Hush, MNSmith, Phak1, tclederman), 148 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#1245654 12/04/2017 4:49 AM
Hi, iam looking for some rims that will fit the stock 10 lug hubs on a 41 chev truck. Does anyone know of a straight replacement? I want to keep the dually set up. The bolt pattern is 190mm 10 lug
Big Bolt Forum Moderator
hi, welcome to the site! I think you will find your answers in the 2nd post down of the big bolts forum (wheels and tires, what to do)
Mike
Crusing in the Passing Lane
190mm x .03937" = 7.480" which is unusual, could they be 7.25", which is a standard 5/10 lug dimension? Anyway, if this the case, I presume they are 20" tires. The only standard replacement is another of the same wheel.
Another option, if they exist in Oz, would be 22.5" tubeless rims, which came out in late '50's trucks when tubeless tires first became available for trucks. They used to be common in the 'states on farm trucks, so that might the best place to look. One can mount up to 9" x 22.5" tires on these rims.
Good luck,
Ed
Hi Cuda,thanks.
Turns out the numbers on the tape measure weren't in the right order and they are in fact 7.25'.
Do you know if the 19.5' rims from the c3500hd fit over the brake drums.
I am not sure on the 19.5s. I have a 2-ton and do know that the 19.5 would look tad small on it (however, mine are the taskforce body style, 55.2-59).
Mike
I don't really mind the slightly smaller diameter so long as they fit over the drums. I'd like to go to maybe an 8.25x 19.5 on an Alcoa type rim.
sorry, I'm not 100% sure about fitting over the drums.
Mike
I had factory 19.5's on my '94/'95 GMC 3500HD, so, I'm sure they will fit yours. However, like was said above, they look undernourished compared to 20's or 22.5's, direct replacement.
Ed
They may or may not fit over the rear drums on the old truck, you’d have to test fit and see.
Tires would be 8R19.5 at 32-33” tall.
Alcoa did make aluminum 19.5” wheels with 10 lug on 7.25” bolt circle, but not any time recently.
I’m not aware of any vehicle they came on standard, possibly some motor home. In any case they’re real hard to find.
1952 Chevrolet 3800 pickup
---All pictures---
I believe those wheels are Aloca part numbers:
761000 not polished
761001 polished outside
761002 polished inside
761003 polished inside and outside
Attached is a picture of some.
Old catalog with them listed. https://www.southwestwheel.com/pictures5/LTFitment-Screen_10-18-01.pdf
Alcoa may have also made these wheels with 6 hand holes (instead of 10 as above) if so these were the part numbers.
763100
763101
763102
763103
---All pictures---
