6 members (JW51, fonz8261, baldeagle, obs2kl, Bill Hanlon, 1 invisible), 59 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#1245396 12/01/2017 9:09 PM
V
V Offline
I'm about to make a trade for a resto-mod 49 GMC 1/2 ton. It has a later model 6 banger that the present owner and I am not sure what it is. I do know I've never seen a valve cover like this one. It has a Quadrajet 4bbl, electronic ign and the bottom pulley has 3 belt grooves. They pulled the radiator to replace the blown electric fan. It's supposedly bolted to a 400 automatic. The truck has been slammed so I couldn't get underneath enough to verify. It does have an open drive shaft and is sporting 15" Cragers and dual exhaust.
Engine pic 1
Pic 2
4bbl Quadrojet
engine bay
I believe it is a 75 up 250 engine with lots of CA air injection smog equipment. The 4 bl & manifold are likely aftermarket.
Fred
V
V Offline
I believe you've got it Fred. I'll verify when I can see it up close and get some engine numbers.
I've found only a couple pics on the WWW of that crazy valve cover setup. It's either longer than the 228 that probably came in it or they mounted it further forward to make the auto tranny and open drivetrain fit. Perhaps this is the reason for the electric fan. I can see alot of that smog crapolla disappearing.
New mysteries to decipher.
Crusing in the Passing Lane
228-302 GMC engines are all about the same length as Chevy 194-230-250-292(7main) engines, probably moved fwd for trans. setup. Pushrod cover on 292's about 6" tall, much taller than smaller engines, in case you can see it.
Ed
Insomniac
Insomniac
The ugly boxes on the top of the valve cover are for the PAIR system. PAIR = Pulse Air Injection Reactor. It pushes fresh air into the exhaust to help the engine burn more cleanly.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
