5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#124534 02/10/2007 1:48 PM
I am looking ahead toward installing metal patches both inside and outside my passenger side door. There are posts that describe methods for doing the welds, and how to smooth and treat the welds for future rust prevention. It occurs to me that treating the backsides of the welds..those inside the door.. is a problem due to inacessibility. I can reach down inside the door with a spray can in my hand but have little control of what I do with it. Any solutions?
meansam
#124535 02/10/2007 3:31 PM
On mine, I washed the doors out really good, let then dry a few days & then poured Rust Bullet(Zerorust, POR-15) inside & kinda moved the doors around to let the stuff cover well. Then after that dried, I filled the corners where the rust starts using brushable seam sealer. This method has worked on my Ford,for 6+ yrs now, & it sits outside year round. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#124536 02/12/2007 12:24 AM
I think you will be OK if you do as "Fleetside 64" suggest. Puting some paint like Rust Bullet in the doors with a rattle can should do the trick. Most rust occurs where there is standing water so be sure your weep holes are OK.
