0 members (), 84 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
#1245123 11/29/2017 2:49 PM
I've never done this. How's it done?
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
We used to use a short piece of plastic tubing to recirculate the fluid from the output port(s) back to the reservoir and purge as much of the air out of the piston bore as possible. Now most MC's come with a couple of plastic plugs for the output ports and the piston is cycled through a very short stroke repeatedly until bubbles stop appearing at the pressure relief port that gets uncovered at the very back end of the piston travel. Hold the cylinder in a vise and stroke the piston 1/2" or so a couple of dozen times to purge the air out of the cylinder bore, then bolt the cylinder into place and quickly connect the line(s). Then the wheel cylinders need to be bled to remove any air that gets trapped in the brake lines during the master cylinder swap. A set of "speed bleeder" screws with a one-way check valve at the wheel cylinders makes the process a one-man operation most of the time.
Thanks Jerry
In the 45 years I've got driving little British Cars. I've never even heard of this...
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
The Little Brit Cars I used to work on had master cylinders with a bore and stroke approximately equal to a Tootsie Roll- - - - -no real need to bench bleed 'em! LOL!
Savannah54 / Julian,
Are you referring to a 1952 or 1954 original style 3100 or 3600 master cylinder (the only pertinent clues in your title and footer-signature).
Or, are you referring to a modification dual chamber master cylinder for what vehicle?
Tim, I was talking about My 3600 (52.) But my question included all that I'd worked on and driven. My 3600 will have a master cylinder from the Holister Road Co. Because of my 4 wheel disc brakes
With a valve to put more pressure to the front wheels.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Julian,
Most likely it is a dual chamber master cylinder?
If it is, people here should be able to describe how to bench bleed it (this would not be described in an old truck manual). And/or, people here might post a link to a page that describes how to bench bleed, or post a link to a Youtube demonstration?
The bench bleeding procedure I described above will work on just about any master cylinder single or double outlet- - - -simply plug the output port(s), fill the reservoir with fluid, and short-stroke the piston until bubbles stop appearing in the reservoir.
Y
yar Offline
Y Offline
Julian,
Here's a video showing how to do it:
Ray
That procedure is ineffective, messy, and at least 20 years out of date.
Thanks All Y'al, Jerry, Every time you say something I'm searching for a new tool. It's Great So far I've gotten a new timing light, a screwdriver socket for my tie bar and now I'm looking for "speed Bleed screws".
It's great reading all that you've got to input here THANKS!!
I've driven little cars all my life. This Truck is my first Big Vehicle it fi, being 6 cylinder. Cause I've never owned a V8 and want'a stay that way. I Love the turns.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
