| | | Forums66 Topics128,081 Posts1,056,073 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | I have transmission with these numbers on side cover trying to get parts for it gm14 3962646 has done rear bearing and would like a repair manual for it
| | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | Have found out what the transmission is 28.5/1.68 ratio 3 peed Saginaw would I be better rebuilding this one or buy a rebuilt Muncie 4 speed have sourced parts from garage motorsports in USA they suggest I put a rebuilt Muncie not sure if I use the same drive shaft
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Unless the transmission has been changed, the factory transmission would be an SM318 Muncie 3 speed. It is easily identified as having a 4 bolt side cover. A later Saganaw full syncro 3 speed would have a 7 bolt side cover and would have been sourced from a 67 up vehicle. You should be able to find a factory repair manual online on this site or purchase one from several aftermarket suppliers. Replacement of the the 3 speed transmission with a 4 speed would require a completely different driveshaft and a replacement floorboard as the 4 speed is taller. I don't see any advantage to going in this direction unless nothing else is available. If all the current transmission needs is bearings, they are available from a number of sources. The front bearing number is 6207 and the rear is 6306. Fred
| | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | Thanks Fred yes it has 7 bolt side cover the tranny shop has found a parts list online will leave 3speed Saginaw in it previously it must of been changed no parts available in Australia I could get the bearings locally garage motorsports are getting me a price for all that I need
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | When you said 4 speed I presumed that you were sourcing a truck 4 speed (SM420) with a granny gear which would require the DS and floorboard changes I referenced. The Muncie 4 speed they are suggesting is likely from a 60's passenger car. They are perfectly fine but would need a floor shift assembly and possibly a fine spline front yoke as well. You may also have an issue with seat clearance with the shift lever. Those Saganaw 3 speed transmissions are relatively cheap here - less than $200 for a good working unit. But of course you are not here. Fred
