0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 34 | I have a 1955 2nd series pickup with a 32 or 34 gallon gas tank located in the rear of the truck bed. The truck came with VDO gauges. The gas gauge registers half full when the truck is full of gas and goes down from that point. I can't tell when I'm getting empty and would like the gauge to show correctly. I'm thinking I'll have to get at the sending unit located on the tank. Is the best way to do that by removing the bed or trying to drop the tank? Any suggestions on the gauge? A BIG thanks for any help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pete O, the gauge and sender must be matched as far as the ohms used, the original gauge and sender used a zero to thirty ohms resistance circuit. We must determine what resistance the VDO gauge operates on and purchase the appropriate sender and install it in the tank. As far as the tank removal is concerned, you can see how it is installed, we can't, in most cases removing the tank is the easier way to get the tank out of the chassis, hope that helps. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | It could be as simple as bending the float arm, the installer may have it bound up in the tank. Start by pulling the sender out and move it from full to empty and see what your gauge reads. If it's still off, hunt down the information on resistance and ohms of the gauge and sender as mentioned above.
I would drop the tank before pulling the bed if you have nice paint. If it is rough, pull the bed, a full tank of fuel will weigh quite a bit. Joe | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | I installed a VDO gauge and sending unit in a car. Below is a link to the type of sender I used. It has to be adjusted correctly for the depth of tank by moving the rheostat up and down and changing the length of the float arm. It's not difficult. Sending unitSounds like the best option for you is to empty the tank and drop it so you can get at it. Remove the sender and confirm that it is set up so that it works across the range.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2012 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 34 | Hey, thanks to all of you who replied. This is a great forum and you guys make it great!!!! | | | | | Joined: May 2009 Posts: 1 Moderated | | Moderated Joined: May 2009 Posts: 1 | I'm getting ready to buy guages from Autometer. I have a 68/69 mustang gas tank on my 54 pickup. They offer two fuel meters, one is a 0-90 ohms, & the other is 240-33 ohms. Which one would be the correct one?
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | I would think it would be the 0-90 one, but check with Autometer. A 240-33 ohms meter implies that the meter understands 33 ohms as empty. Original meters always understood 0 to be empty. | | |
