| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I'm looking at buying a rebuilt SM420 for my '51, and I've been doing some research on gear oil. From what I can glean from the internet, GL-5 oil is out. I have read some good reviews of Sta-Lube 85W90 GL-4, but it seems a bit pricey at almost $38 a gallon. Then I found that Coastal has 90 weight in both GL-4 and GL-1, at about $10 a gallon . Does anyone have any experience with the Coastal oil? Any opinions on GL-1 versus GL-4? GL-1 seems like it would be more in line with what was available 50 years ago, but that may not be the best. Hopefully, things here don't get as heated as they do over motor oil preference.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I saw that Quick silver Marine SAE 90 is the best for our SM420'S--Bill. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Coastal is fine.
SAE 90 "multi-purpose" gear lubricant was specified.
Any brand should be OK. I have used Coastal. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | NAPA carries a GL-1, and I recently got some Lube King GL-4 90W in a 2 gallon container for a very good price even with shipping. (Google it)In fact I bought two!
Ed
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Valvoline Synchromesh is a GL4 oil. They claim to be good for pretty much everything. | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Thanks for the replies, everyone.
The Quicksilver looks good, but a bit much for my current budget, Bill. I can order a gallon of Coastal for what a quart of the Quicksilver costs. With having two kids and three grandkids under my roof, I have to really watch the dollars.
I'm not sure that Valvoline has Synchromesh available anymore, Whitedog. I searched their website, and it wasn't found. What they did have on their site was rated GL-4/GL-5, which from what I've read is the same as using GL-5.
Thanks for giving me a bit more confidence about the Coastal, Tim. If I can't find anything at NAPA like Ed suggested, I am planning on ordering the Coastal I found online.
Any discussion about GL-1 versus GL-4 in our applications?
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | The GL-4 has a few more additives for anti-rust, anti-foam, etc. which might not be absolutely necessary for use in a transmission, but "nice to have". The main concern is to avoid the extreme pressure additives the GL-5 has which can attack bronze parts such as synchronizer rings. I used to do a lot of business with a Fuller Roadranger transmission rebuilding shop in San Francisco when I ran a truck shop out there. They had 55-gallon drums full of trashed synchronizer rings caused by people running hypoid gear lube in Roadranger transmissions. Jerry
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I was able to check a couple of places in town today. From what I saw, straight SAE 90 is still safe. All multi-viscosity oils I found today were either GL-5 or GL-4/GL-5. AutoZone had Pennzoil Synchromesh, which is GL-3, for $8.99 per quart. Our local farm store had Champion SAE 90 GL-3 for $27.99 per 2-1/2 gallon jug. NAPA was closed by the time I got there. At least I have options locally.
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | My local Tractor Supply carries SAE 90 GL-1 labeled Ford Tractor Gear Oil...was about $18.00 for a 2-gal jug. NAPA has SAE 90 GL-1 in a 1-gal jug for about $13.00, I just bought some last week for my Bolens Garden Tractor. Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thank you very much, Mike I hope this information is read in the future. SAE 90 GL-1 will work very well, and the price is right. hmmm, there must be a more expensive, synthetic, multigrade, race-car-rear-end replacement?  | | | | | Joined: Aug 2017 Posts: 127 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 127 | Would the Tractor Supply GL-1 SAE 90 Ford tractor oil be good to use in the 4 speed transmission of my '51 2-ton? It has a PTO attached, if that makes any difference. Or would something GL-4 be better? The truck doesn't see a lot of use, but when it does, it's usually hauling about 12,000 lbs of grain, so I imagine there's some strain on the transmission that would need a pretty good lubricant, which might call for the GL-4? Tell me if I'm wrong, and if so, what the best option would be. Thanks!
1951 Chevrolet 6400
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | SM420 transmission? GL-1 SAE 90 is OK - SAE 90 was original spec. Novak Transmissions: "An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment." | | | | | Joined: Aug 2017 Posts: 127 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 127 | I'm still pretty green, so how do I tell what transmission I have? All I know is the truck is a 6400, 4 speed, with a hi/lo rear axle. Thanks!
1951 Chevrolet 6400
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GM switched from the SM-420 4 speed to the SM-435 4 speed and NP-540 series 5 speed in 1967/1968.
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 235Kidd - always list the year (with the make/model - which is apparent in your post). | | |
