0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | Can the door of a 56 3100 be adjusted outwards(away from the door hole)The front edge is about half inch below the fender when shut.Fender position looks to be ok.Could do with just pulling the front edge of the door away from the body by half inch.Any suggestions or is it time to get the hammer out.Gaps around the door are ok ish! Thankyou | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1/2" sounds a bit much, but the door should be shy of the fender to avoid wind whistle, as it was from the factory - like this - also prevents binding and chipped paint .... shimming of either side of the hinge could shift things a bit Bill | | |
