8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Does any one use the permatex rust converter you see in the parts stores. comes in the little white plastic bottle? is it any good? I have used it once, turns the rust to a black hard substance.I never had that car long enough to see if the rust came back.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's just phosphoric acid with a bit of jelly added to make it stick, just like naval jelly. It works well on lightly rusted parts and as a metal prep. Its best to grind off all the rust you can first though.
