1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I ran a search and did not find anything specific on this subject. I did some touch up work on a non stovebolt today with a paint that had a lot of metalic in it. After wiping it off with lacquer thinner 2 times because it sagged and the metals puddled, I fogged it very lightly and let is rest about 10 minutes and did the same thing again several more times and got it to where it was acceptable. The paint is PPG DCC the same paint I always use, but I have never encountered this problem with non metalic paints. I certainly would not want to try and paint a complete vehicle like this. Anyone have any explanitions or advice? | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Very light to transparent 1st coat. Let it tack for 15-20 min then hit it again. Wait 15 min. between coats. | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | This was found on the Dupont website in their technical manual concerning bc/cc systems when using high metallic base colors.
Apply two medium wet coats or to hiding. Allow each coat to flash dull/dry. For high metallic colors, use a mist coat in conjunction with the final coat for best flake control.
Hope this helps. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I always do a mist coat at the end to even out the metalic. It seems to help. I always use bc/cc now. Dont know how well it would work on enamel though. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Thanks for the response guys. Sounds like I was on the right track. It's just a process that can't be rushed. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Also it helps to shake the paint gun now & then to keep the metallic mixed well. Brian | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | I have found it to be a problem when using gravity feed guns and the flakes seem to settle to the bottom of cup.
Ridge dweller
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Also try keeping a couple marbles in gun to keep metallics floating
Dan | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Make sure you spray at the proper temp. I tried spraying metallic one time when it was too cold and the heater was broken in the booth I was using and it was a nightmare. Also when you fog your last coat keep your gun at least 12" away from the surface and spray diagonally. Works great! | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | may want to add a fast dry thinner will kick paint faster | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | fireout1, It was too cold, I was outside touching up a panel on the motor home. And chev4t6 the marbles sound like a good idea. Fortunatly the antique vehicles I restore did not use metalic paints and with luck I may not have to fool with it again Thanks to all for the feedback. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I have used steel balls in the paint cup when spraying "metal flake" and NOT in metallic paint..spraygun technique is the key here.. Its very easy to take a spraygun and get as many as a dozen different colors using the same cup of paint...Fan adjustment, air pressure, fluid tip and needle adjustment, air cap choice, and this is provided the paint material was reduced, or thinned to start with...Your metallic's found in B/C C/C are micro chips and are plastic, and will stay suspended in the cup, just as acrylic lacquer will...however, if You set Your spraygun down for an half-hour or so, then it would be recommended to stir the paint in the cup again...and as previously said, Your thinner should be matched to the temperatures You are working in, to flow properly...Bill B | | |
