5 members (Jay R, Jon G, Joe H, TUTS 59, 68ironhead), 107 guests, and 2 robots.
Topics128,049
Posts1,055,747
I have 54 3600 pu and I am replacing all the felt around the pass window. Don't ask me why I used a spray lube to make the window roll up easier. It just makes a rubbery mess after a couple of years. My question is what is the best way to install the vertical felt strip on the vent window? I know you can use a board and hammer but I don't want to distort it. I have used dish soap on motorcycle grips and that works great. What is you alls opinion?
Thanks Sharon
Fox Offline
When I did mine recently on my 53, I used a tiny bit of glue and said board with my vice to set the felt channel. The glue acted like a lube and it slid right in. Then I wrapped it with electrical tape every few inches to ensure it stayed in place and let it dry. Also, the reproductions I got from classic parts are rubber backed so they wedged in very tightly. I assume that they might hold in place by themselves without glue too. While you're at this stage check your vent window vertical seal on the vent glass. If it's shot, now is the time to replace it as you need access to the rivets that are under the window felt.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I changed out that rubber when I did all the weatherstripping. What kind of glue did you use? The verticle strip is rubber backed and seems when you get it in place it should stay.
Fox Offline
3m weatherstrip glue very sparingly.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
