2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I have wrestled with the hood on my '70 C10 trying to get it to sit down in the back and nothing has worked. I have noticed a fair amount of movement (probably from wear) in the area of the hinges where a flat piece of metal is riveted between the front and rear sections of the hinges. Could this be an indication that it is time to replace the hinges? Take a look at the pics to see the area I am referring to. hood hinge hood hinge 2 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You've hit the nail on this one. My '55 did the same thing, when I put the new hinges on, the problem was cured.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Thanks, Bill. Guess I will start shopping around. | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Is it necessary to replace the hinge springs when I get new hinges or can I use the springs from the old hinges? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's best to replace them, and most of the hinges are supplied with new springs - that "flattened piece" is actually the rivet that's the hinge pivot, and wear there is what causes that problem as Bill sez above
Bill | | |
