0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#124442 02/05/2007 12:41 AM
I have wrestled with the hood on my '70 C10 trying to get it to sit down in the back and nothing has worked. I have noticed a fair amount of movement (probably from wear) in the area of the hinges where a flat piece of metal is riveted between the front and rear sections of the hinges. Could this be an indication that it is time to replace the hinges?
Take a look at the pics to see the area I am referring to.
hood hinge
hood hinge 2
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
You've hit the nail on this one. My '55 did the same thing, when I put the new hinges on, the problem was cured.
Bill Burmeister
Thanks, Bill. Guess I will start shopping around.
Ralph Davis
Is it necessary to replace the hinge springs when I get new hinges or can I use the springs from the old hinges?
Ralph Davis
it's best to replace them, and most of the hinges are supplied with new springs - that "flattened piece" is actually the rivet that's the hinge pivot, and wear there is what causes that problem as Bill sez above
