| | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | Has anyone had an issue with the mesh filter on the sending unit causing their truck to stall? The tank is brand new and the fuel is brand new. When i put in the sending unit with no filter it runs fine, switch it out with new sending unit with filter and it dies after driving it for several minutes.
Any ideas?
1955 1sr series, 235 | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I would say that you have an issue down stream of the filter sock. Likely the fuel pump. It may be pumping just enough without the sock, but isn't functioning well enough to overcome the relatively minuscule resistance created by the sock. That's my 1 cent anyway. (My opinions have been downgraded by 50% due to recent wrongness.) Carl
