| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Getting to the point of needing to get the headliner in the suburban. Out of all the vendors out there who's had good luck with one of the re-pop headliners? I'm looking to stay stock and don't mind the cardboard.
Weeds headliner looks good, but I can't seem to find where he got his from.
Thoughts?
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Bought mine from classic parts this year and it fit good and installed pretty easy. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Weeds bought his from LMC. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bought mine from JC many years ago. It did not fit well at the corners/edges. There were gaps. http://www.1954advance-design.com/SubHeadliner/index.html (on the second page are some photos of the insulation I installed) ALSO, I suggest you seal the edges/back of the cardboard with epoxy/urethane paint to help to decrease moisture absorption and the resulting distortion of the cardboard. When the cardboard distorts, it drops out of the metal "divider" strips between headliner pieces. A member reported a few years ago on his project to make those panels out of plexiglas, so as to not worry about distortion after installation. I'll look for that post, and post a link here if I can find it. Here is the thread with Mark's nice work.Also, Here is a thread about metal "stays" to keep the cardboard flat. They usually "disappear" when the cardboard falls out (and/or is removed).
Last edited by tclederman; 11/16/2017 3:43 PM. Reason: added link to Mark's nice job, and parts from KC Mongo
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Great info guys, thanks.
Is it best to install headliner first then the door opening seals? Or install the door opening seals and then the headliner?
