3 members (moparguy, stlcardinalsguy, Cosmo), 141 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#1243501 11/16/2017 1:15 PM
Bondo Artiste
Bondo Artiste
Getting to the point of needing to get the headliner in the suburban. Out of all the vendors out there who's had good luck with one of the re-pop headliners? I'm looking to stay stock and don't mind the cardboard.
Weeds headliner looks good, but I can't seem to find where he got his from.
Thoughts?
~ Phillip
Bought mine from classic parts this year and it fit good and installed pretty easy.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Weeds bought his from LMC.
Bought mine from JC many years ago. It did not fit well at the corners/edges. There were gaps.
http://www.1954advance-design.com/SubHeadliner/index.html
(on the second page are some photos of the insulation I installed)
ALSO, I suggest you seal the edges/back of the cardboard with epoxy/urethane paint to help to decrease moisture absorption and the resulting distortion of the cardboard. When the cardboard distorts, it drops out of the metal "divider" strips between headliner pieces.
A member reported a few years ago on his project to make those panels out of plexiglas, so as to not worry about distortion after installation. I'll look for that post, and post a link here if I can find it.
Here is the thread with Mark's nice work.
Also, Here is a thread about metal "stays" to keep the cardboard flat. They usually "disappear" when the cardboard falls out (and/or is removed).
Last edited by tclederman; 11/16/2017 3:43 PM. Reason: added link to Mark's nice job, and parts from KC Mongo
Bondo Artiste
Bondo Artiste
Great info guys, thanks.
Is it best to install headliner first then the door opening seals? Or install the door opening seals and then the headliner?
~ Phillip
