2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#1243487 11/16/2017 4:21 AM
Replacing my 1950. 216 with a 1956. 235. Was cleaning up rocker arm assembly on the 235 and found the rocker arm shaft kind of funky. Worn spots. Can I replace it with the rocker arm shaft from my 216???
evac34 #1243488 11/16/2017 4:29 AM
Shaft from 216 will work fine. Use your 235 rockers and clean everything up really good.
1951 3100
evac34 #1243528 11/16/2017 5:00 PM
so I checked all the rocker arms and they too are bad. Need to get a new assembly. Where is a good place to get these from??
evac34 #1243531 11/16/2017 5:48 PM
Are the rocker bores worn where they ride on the shaft or the tips?
Tips can be pretty easily resurfaced. Worn bores might be a little more complicated and require a re-busing or such.
Search for a recent thread, actually one I started, for a lengthy discussion. I think the title may have been “rocker tip wear” or some such thing.
My machine shop was able to source new shafts. I ended up using some good ones off a different engine. Not sure if new rockers could be found other than NOS.
1951 3100
evac34 #1243537 11/16/2017 6:37 PM
New shafts are readily available.
Do you want web-links to companies that "re-hab" the assembly and/or "rockers"?
http://www.rockerarms.com/pages/gm.html
Chevs of 40s sells a re-habbed assembly, with your core.
https://www.chevsofthe40s.com/dept/Engine/cat/Cylinder+Head.html
Kanter & Egge used to sell rocker arm assemblies/parts.
