| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | Replacing my 1950. 216 with a 1956. 235. Was cleaning up rocker arm assembly on the 235 and found the rocker arm shaft kind of funky. Worn spots. Can I replace it with the rocker arm shaft from my 216??? | | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Shaft from 216 will work fine. Use your 235 rockers and clean everything up really good.
1951 3100
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | so I checked all the rocker arms and they too are bad. Need to get a new assembly. Where is a good place to get these from?? | | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Are the rocker bores worn where they ride on the shaft or the tips?
Tips can be pretty easily resurfaced. Worn bores might be a little more complicated and require a re-busing or such.
Search for a recent thread, actually one I started, for a lengthy discussion. I think the title may have been “rocker tip wear” or some such thing.
My machine shop was able to source new shafts. I ended up using some good ones off a different engine. Not sure if new rockers could be found other than NOS.
1951 3100
