4 members (Bill Hanlon, Otto Skorzeny, NJC, 1 invisible), 107 guests, and 2 robots.
Topics128,034
Posts1,055,539
Members48,425
#124323 01/31/2007 4:02 AM
Any pitfalls in using a cup style while stripping paint of of the grill of a 1960 GMC. It goes really great. After I strip the paint, I will wipe down with laquer thinner and acetone before priming.
On the wipe-down is aircraft prep any different (better/worse) than acetone?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#124324 01/31/2007 4:10 PM
have used them quite a bit, the cups that is...wear eye protection, or I wear a face shield, those wire tend to fly off sometimes.
Mike
#124325 01/31/2007 10:26 PM
Any thoughts on what to use on the wipe down, prior to priming?
#124326 02/01/2007 3:03 AM
I used some PPG Degreaser/Wax remover myself, got the metal squeeky clean prior to shooting primer.
#124327 02/01/2007 5:01 AM
#124328 02/02/2007 10:15 PM
Norton makes a paint-rust stripper disk that looks like swiss cheease with grit on it. They make them in diffrent grits, but those things will strip paint like you have never seen, and not burnish or grind the metal. They don't build up heat like a cup brush. Do yourself a favor, try one. I stripped a whole 55 Buick once with a cup brush, the Norton disk would have taken 1/4 the time, quieter, and cleaner, with better metal prep. Costs about 8 bucks.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
#124329 02/04/2007 4:12 AM
O.K. I 'll look for one at Autozone.
#124330 02/04/2007 3:38 PM
55 Buick. COOL
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
