1 members (Donf), 102 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
#124295 01/30/2007 4:40 AM
Does anyone know of a company that sells a patch panel for a 57 3200 roof header? I couldn't find one at Classic Parts, American Classic or Obsolete Chev. My roof panel is O.K., but the panel from the windshield pinch weld up to the roof panel on the outside is rusted through, and the inside header panel above the windshield glass is also rusted through. The truck set for years and mice built a nest in between the inner & outer header and rotted the metal.
I guess the little varmets are getting me back for shooting so many of them with my BB gun when I was a kid.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#124296 01/30/2007 6:24 AM
I've never seen either header or eyebrow patches - it's a DIY project
#124297 01/31/2007 2:02 AM
It sounds like this area is kind of common for rust problems. I thought about trying to find a good panel out of a parts cab, but would probably be quicker & less trouble to make one myself like you said, Red58.
#124298 01/31/2007 6:29 AM
I was certain their was a patch panel, and like you said, it is a common spot for rust.
That said, surely someone here has redone that panel and could give you/me(for future reference) some tips.
Good Luck.
#124299 01/31/2007 10:58 PM
You have to find someone with a parts cab who will give you a section of it or bend up your own panel.
Most of the time these sections are rusted from the inside out, by a mouse nest.
Paint & Body Shop moderator
#124300 02/01/2007 1:46 AM
You might keep a watch out with the suppliers, seems there are more and more body panels coming out for the TF body. I have heard that Dynacorn (the crate Camaro guys) are going to do a '55-59 cab, so the panels you need will most likely be available soon.
Bill Burmeister
#124301 02/01/2007 11:50 PM
I had the same problem on my 59 small window. When I pulled the roof skin off and welded in the big window frame and supports, I found the previous owner had fiberglassed this area. I made my own, but what a pain, it is curved in three dimensions. Fiberglass seems the easiest way in hindsight. The previous owner had glassed it from the inside, so I guess the roof was off once before. Hope it helps. :rolleyes:
They named it Apache cause it has a patchy welded here and a patchy welded there.
