0 members (), 329 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
I recently picked up a 1966 C60 and it seems like the syncros in third gear are pretty far gone. The truck has the 327 and a four speed trans. Have to be pretty patient and sometimes double clutch it to get it to go into gear. With a load on the back those extra seconds of fighting the trans equate to a lot of momentum loss! The truck will go ~50 mph if pushed, but in an ideal world I'd like to get 60 mph out of it.
The question is, is it worth rebuilding the transmission or should I be looking around for another transmission with overdrive? I've done a little searching and it seems like the O/D transmissions do exist that would bolt right up, but aren't readily available? The part I haven't looked into is how hard it is to rebuild the trans and/or how readily available parts are going to be for it.
Any suggestions or insight would be welcome!
Trey Wilkins
1950 Chevrolet 3100 Five Window
1954 Chevrolet 4100 Dumptruck (Sold)
1957 Chevrolet 6400 Dumptruck
1966 Chevrolet K20 Longbed Fleetside
1966 Chevrolet C60 Grain Truck (Sold)
More pix on Photobucket
I'm not too familiar with a newer type trans swap, but the old way would be to install a 2-Speed or 3-Speed Aux Trans with an Overdrive behind what you have now.
Do you feel like your Trans now is about to give up or is it just hard to shift into 3rd?
I had a 5-Speed in a '62 that had trouble getting into 3rd, but Double-Clutching it every time cured it. I would actually Double-Clutch every gear anyway and after a while, you would actually forget it had an issue, lol.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
You need to establish what trans you have before the question of who can supply parts can be answered.
Your truck would have the SM-420 4-speed as standard issue or it could have been ordered with a NP-435 4-speed.
The SM-420 has the PTO on the drivers side and has this shift pattern;
...1..3
R..2..4
The NP-435 has the PTO on the passenger side and has this shift pattern;
1..3
2..4..R
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Most 2 speed rears have slow and slower ratios. Figure out what your existing ratio is to start with. NV-4500 is an OD thanks that would work. SM-420's are easy to rebuild.
Ed
Overall, the trans feels ok it's just third gear that has issues. The shift pattern matches the SM-420.
What was the NV-4500 available in originally?
Trey Wilkins
Isn't there a 5 speed trans that came in 90's pickups that was fairly heavy duty? I haven't looked for years but I think it is a big ugly aluminum thing .I suppose all the bolt patterns are wrong though.
1949 3100
4500's were installed in GM and Dodges from the factory. Dodge bolt pattern have longer input shaft, 1"(approx.) spacer with old GM bolt pattern fits GM, or drill and tap GM case with old GM pattern.
Early 6 speeds(forgot the model desig.) with an integral oil pump were in GM(only a few years) and Fords. Lots of parts support for 4500's.
ZF in modern Dodge and Ford.
Ed
