1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Not quite sure what my friend has in his 69' chevy truck, stampend in on the heads reads Mexico? It is an 8 cylinder with the number stamped 1M0311 9VP, on the r/h fwd. side of the block. If you come up with anything let me know. Thank you. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Probably a Chevy crate motor? Those are made in Mexico now.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | By chance does anybody have a book on crate engines? I don't think I've ever seen a number like that. It most likely is a 350", but then again I don't know. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Get the casting number off of the back left top edge of the block ...that will tell you what you have. Mike B  | | |
