| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | Just finished installing one side of the cab windlace and the top rear corner angle looks terrible. I figure there must be a trick/method to make the rubber conform to the curve but can’t find anything about that. Has anyone else had this problem and if so, how did you correct it?
The rubber is securely in the channel thru the curve but is “wadded” up at the corner.
'53 3100 Short Bed Texas Peace Officer - supporter of the Badge and the Blue Line Pain is part of life, Misery is an option.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | Brad.......photos sent to email
thanks 5ptstar
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** 5ptstar ** Just sent you a pm as to how I installed my Jim Carter windlace with zero kinks. ** | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | There was a post a while back about the colored windlace being made from a material of a different density than the black windlace, and it wasn't possible to fix it. If you are not able to get it to lay right, at least it will take your attention away from the headliner gaps caused by cardboard shrinkage later on.  Carl
