0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | The heat valve on my exhaust manifold will not turn. Sprayed pb blaster still not moving. It is on a 1956 235 anyone have any ideas on how to free this? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Long process. Keep spraying with penetrating oil and tap (not beat) with a hammer. It may take several days. Others on here have had success so maybe they will put their two cents in.ðŸ›
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Yep....been there. It takes a regiment of spraying aerokroil every day. Tap tap tap with hammer. Then a pair of vise grips on the post to wiggle it slightly over time. It works.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Some of them need the application of a a Victor Hot Wrench before they free up. Jerry
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I tried moving the end opposite of the spring. The large balancer I guess. That moves but not the rod it is attached to. Just moved it slightly. I'll keep soaking hope I didn't do damage | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if it is stuck in the heat off position, you could probably not even worry about it, Mine had the spring broken off for probably 20 years, I actually had no idea what it was or what it did, the truck just started and ran so well, I never looked for a problem. Even at 20 below zero, it ran like a champ. The little flapper is hardly a tight seal, and the two parts are bolted together so closely heat transfer is quite good anyway. But if it is in the heat ON position, then you will have trouble. But yes if you feel you really need it to work, Just be patient, you will need patience if you are going to work on these trucks anyway. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | If the weight is moving, even slightly, that is a good sign. That's usually an early indication that it is about to break free. Use the advice given above plus grab the weight with a large pair of Channelocks and twist in both directions.
They get jammed up with carbon. Sometimes they will free up with the carb and intake installed, sometimes not. If the latter, remove the carb and the intake to get at the inside of the valve. Scrape away as much carbon from the pivot points as you can with a small screwdriver, then hit it with Kroil from the inside and repeat the tapping/twisting procedure described above.
I have had them take over a week to break loose with spraying and tapping a few times a day. Persistence pays off. Usually, you'll first feel a little side to side give when you tap on the shaft, then the weight will start to wiggle. That's an indication that you are in the home stretch.
Good luck,
Matt | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | The folks above nailed it . I had the same problem and used PB Blaster to free it up. It was not quick or easy, but with a lot of patience ( as in soak, tap-tap-tap with the hammer), soak again....etc, it can be done. It took a couple of days of spraying and letting it "soak" . I found that tapping the ends of the rod worked best for me. Tap left to right, right to left and soak the crap out of it and let it sit. I'm not the brightest, apparently, because I tried tapping up / down on the counter balance weight and bent it down, straightened it back out........ Its free as a bird now. I think you'll get it with that method, if not, there's Jerry's Victor Hot Wrench.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | If the weight is moving, even slightly, that is a good sign. That's usually an early indication that it is about to break free. Use the advice given above plus grab the weight with a large pair of Channelocks and twist in both directions. The OP stated that the weight "moves but not the rod it is attached to." If he keeps torquing on the weight, it will snap something off.
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | if it is stuck in the heat off position, you could probably not even worry about it, Mine had the spring broken off for probably 20 years, I actually had no idea what it was or what it did, the truck just started and ran so well, I never looked for a problem. Even at 20 below zero, it ran like a champ. The little flapper is hardly a tight seal, and the two parts are bolted together so closely heat transfer is quite good anyway. But if it is in the heat ON position, then you will have trouble. But yes if you feel you really need it to work, Just be patient, you will need patience if you are going to work on these trucks anyway. Hey Broke, hear me out. I ran a '52 with a flapper stuck in the closed position for 20,000 miles without drivability issues. The climate in Virginia Beach, VA is entirely different than Connecticut, but it does get cold enough to warrant having this thing functional. Even though it ran fine upon startup and throughout the warmup period during cold weather, I am certain that a lot of non-atomized fuel got dumped into the cylinders, washed the oil film off of the cylinder walls and contaminated the oil with gas. Atomized fuel hits the cold intake runner and instantly becomes liquid fuel which does not burn. That is exactly why GM spent all that extra money designing and manufacturing that intake heating apparatus. The lack of a functioning heat flapper will reduce the life of an engine. It isn't something which you would notice on a daily basis, but it is happening just the same. Carl
