7 members (Jay R, Wayne67vert, Phak1, 3B, DaveV, Hush, walter74),
110
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | I have just lifted the body off the frame on my 62 suburban and the frame rail body mounts are rotten where the rubber mounts would go. should I just repair this by cuting the mount back to good steel and welding in plate steel with the appropriate holes? or is there a better way to do this?
it's not how much time you spend on it, it's how you spend your time with it
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | should be able to find at least some of the mount "patch panels" at one of the vendors, at least the ones common to pickups, and the ones further back may be the same - like here, called \'floor supports\' Bill | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | those are great for the cab I am talking about the mounts on the frame that the cab bolts to.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Welding in new metal to the frame cab mounts would appear to be the best option unless you can find replacements and replace the entire mount. Since no one but you and the next guy who removes the body will ever know I would weld in new metal. | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | thanks for the info. does anyone know where I can get the specs for the hole dimensions diameter and location?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 60-66 factory assembly manual available at any vendor - useful if you're doin much work on it Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The front mount supports are the same as pickups, but the rest are different & will require fabbing. Brian | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | thanks for the great reply's the factory assembly manual is next on my list of things to get. As I guesed there will be no easy way around this an I am gona have to get down and dirty to get the job done right Starting from the bottom and working my way up Burbnburp
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Burp Send pictures. We love pictures
~Jim
