Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 71 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#124197 01/19/2007 8:01 AM
Apprentice
Apprentice
I have just lifted the body off the frame on my 62 suburban and the frame rail body mounts are rotten where the rubber mounts would go. should I just repair this by cuting the mount back to good steel and welding in plate steel with the appropriate holes? or is there a better way to do this?
it's not how much time you spend on it, it's how you spend your time with it
#124198 01/19/2007 8:10 AM
should be able to find at least some of the mount "patch panels" at one of the vendors, at least the ones common to pickups, and the ones further back may be the same - like here, called \'floor supports\'
#124199 01/19/2007 2:51 PM
Apprentice
Apprentice
those are great for the cab I am talking about the mounts on the frame that the cab bolts to.
#124200 01/19/2007 3:21 PM
Anonymous
Unregistered
Anonymous
Unregistered
Welding in new metal to the frame cab mounts would appear to be the best option unless you can find replacements and replace the entire mount. Since no one but you and the next guy who removes the body will ever know I would weld in new metal.
#124201 01/20/2007 10:01 AM
Apprentice
Apprentice
thanks for the info. does anyone know where I can get the specs for the hole dimensions diameter and location?
#124202 01/20/2007 6:39 PM
the 60-66 factory assembly manual available at any vendor - useful if you're doin much work on it
#124203 01/21/2007 12:55 AM
The front mount supports are the same as pickups, but the rest are different & will require fabbing. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#124204 01/21/2007 4:45 AM
Apprentice
Apprentice
thanks for the great reply's the factory assembly manual is next on my list of things to get. As I guesed there will be no easy way around this an I am gona have to get down and dirty to get the job done right
Starting from the bottom and working my way up
Burbnburp
#124205 01/24/2007 5:00 AM
Burp
Send pictures. We love pictures
~Jim
