| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 32 | I have recently run up a 235 chevrolet engine the Number starts with KEA. I have oil getting in the water, some one said it may be an oil pipe through the water jacket, doe any body have any other ideas.
Thank Howard | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | If it is a '52 engine, it will have a copper pipe running through the block. Remove each end of the copper pipe, plug one end and put a Mity-vac on the other to see if it holds a vacuum. You will need to remove the valve cover to remove one end from the rocker shaft fitting, and remove the other end from the oil distributor on the driver's side of the block. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | KEA = 1952 235 6000 series truck | | |
