| | | Forums66 Topics128,184 Posts1,057,195 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | The other day I found that the spring on the choke rod on my '56 235 has broken one of it's "hooks" and it's now not returning (opening the choke when I push the choke cable back in). Now that I've taken a close look at the set up, I'm seeing what looks like a rectangular 'riveted rod end', for lack of a better term. Is it possible to change this broken spring on this rod, or am I going to have to put on a different carb top (or full carb) to fix this simple problem?
"When I rest, I rust" 1951 3100 5 window w/ '56 235
