Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Dennys28, Maybellene, Southerntruck, Bill Hanlon, baldeagle, TexasA&M48Truck), 49 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
#1241229 10/29/2017 9:36 PM
Well I decided to check the valve lash today on a cold soaked engine and expecting to find lots of clearance I found mostly the opposite. Intake varies from 2 to 12 thou and exhaust 7 to 18. Don't know the history of the truck really. Just rebuilt the carb because it wouldn't start or accelerate well and found it was recently gone through and not done correctly. Are the valve seats getting worn, or did someone possibly not know what they were doing? Thanks in advance.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
What make, size, year engine?
The one in the sig, 1953 GMC 9314. Being Canadian, supposed to be the 235 that the US got in 54? 2 nuts on the cover, but has 60 PSI gauge? I'm still figuring this old iron stuff out. I followed the procedure on deves tech net. Could the rocker face be a bit beat out making it seem tighter on the feeler gauge? Engine is really quiet except what sounded like 1 or 2 valves rattling a bit. Thanks!
Lindsey,
Yes, grooves worn into the rocker-arm face cause bad readings/settings.
I carefully grind-flat and polish the mating surfaces.
What gap/lash settings did you try to use?
I haven't adjusted anything yet, I just wanted to see where they're at and figure out a game plan from there. Whoever was in there last used only RTV to seal the cover so that was a treat to remove. Also the acorn nuts had a pile of washers underneath and liberal amounts of RTV as well. Any idea what's supposed to be under the acorn nuts? As weather allows I'll look at the rockers. I've read to add anywhere from 0.002-0.005" extra to a cold engine
Crusing in the Passing Lane
I have made thick teflon washers to go under the one steel washer under each acorn nut, studs can be threaded further into head if too long. If over tightened, can distort valve cover.
Ed
Awesome thanks, I could only find the nuts which I already have
