0 members (),
166
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | This truck was converted to 12V back in 2001 and all gauges were replaced. I gave the truck to my father and he returned it several years ago when he was no longer able to drive it. The fuel gauge needle constantly moves, it doesn't stay at one point. At first I thought this might be a condenser but the needle does this even when the engine isn't running (key on of course). I replaced the condenser in the distributor and that did not solve the problem. Anyone have any ideas about this? 1953 Chevy 3100 fuel gauge - youtube video
1953 Chevy 3100 Pickup 1954 Chevy 6400 Grain Truck 1957 Pontiac Transcontinental 1958 Buick Limited 2 Dr 1968 Ford Galaxie 500 1974 Ford F-350 Flat Bed (Dump Bed), former Pioneer Seed Truck.
"Beer is proof that God loves us and wants us to be happy." ~ Benjamin Franklin
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Find where the ground wire which comes from under a screw on the sending unit. Follow it to where the other end of the wire which should make contact with the bottom of the cab under the driver seat. That is the factory correct location for it. Remove the nut and bolt and clean the metal for a good ground. That is where I would start.
| | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | Thanks, I'll try to check that this week.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Yours is a very interesting problem. I spent most of my career in instrumention of some sort and don’t remember ever seeing it. The gauge needle is going full tilt to both pegs and very quickly at that. This makes me think that you might have a ‘dirty’ supply voltage if the truck was running. I would troubleshoot the problem by first disconnecting the sender wire at the gauge. With key on, if the problem goes away you know where to start looking. If it stays, I would remove the (+) side wire and use a battery charger clipped to the (+) side of gauge and negative side of charger to gauge housing. If problem is gone then it’s in your voltage supply wire or gauge ground. If it stays then your in the market for a new gauge. Good luck
