Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (JW51, cmayna, lumbersawyer, FAST55), 513 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
I
I Offline
I'm getting a full tank reading all the time. I installed a generic fuel sending unit in when I first got a new tank without thinking about the fact it was most likely for 12v systems. I installed an extra ground wire just to make sure but don't think that was my issue.
Can I install a resistor or even a variable resistor in the hot line from the gauge to dial in the right reading?
Thanks, Larry
1949 3600 completely stock
1949 3600 216 4 speed (completely original)
Larry what is the ohm value/range for the sender you bought?
http://www.tanksinc.com/index.cfm/page/ptype=results/category_id=159/mode=cat/cat159.htm
I
I Offline
Took me a while to find the info.
Empty - 240 ohms; 1/2 - 130 ohms; Full - 33 ohms
Thanks, Larry
Sir Searchalot
Sir Searchalot
Sending units don't care about voltage. There is NO voltage to a sender. The gauge needs whatever voltage it is designed for. The gauge must also match the ohmage of the sender. Your stock gauge is 6V 30 ohm. The sender must be a 30 ohm for it. But it sounds like you have changed something if you bought a generic sender instead of a stock sender. Can't help you if we don't know what you have.
There is a stock 6V gauge, a stock 12V gauge and a stock sender, that works for either gauge, available for 49-53.
Your signature says "completely original".
1. 6V or 12V system?
2. Original "new tank"?
3. Original gauges?
4. Why did you buy such a funky sender?
Ex Hall Monitor
Ex Hall Monitor
Your fuel gauge is made to work with a 30 ohm sending unit. The sender should provide no resistance when in the empty position (~0 ohms) with progressively increasing resistance as it reaches full resistance (~30 ohms) at the full position. Generic 30 ohm sending units are available from all of the vendors.
I
I Offline
Ok thanks for the info, I definitely didn't understand this. So the "always full" reading makes perfect sense. I'll replace the sending unit with a 0-30 ohm unit and should be fine.
I
I Offline
I changed the sending unit to the correct 0-30 ohm sender and made sure it's grounded. It is currently reading 20 ohms and the tank is about 1/3 full (from looking down the hole). However it is still pegging the gas meeting to full. When I shut off the key it will go back to empty. It also sticks after I tune of off and I have to tap on it to return to empty sometimes.
Any ideas? Thanks Larry
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.027s Queries: 14 (0.024s) Memory: 0.6181 MB (Peak: 0.6891 MB) Data Comp: Zlib Server Time: 2025-09-22 15:20:33 UTC
Valid HTML 5 and Valid CSS
