BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,282 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2017 Posts: 19 New Guy | New Guy Joined: Sep 2017 Posts: 19 | I'm getting a full tank reading all the time. I installed a generic fuel sending unit in when I first got a new tank without thinking about the fact it was most likely for 12v systems. I installed an extra ground wire just to make sure but don't think that was my issue.
Can I install a resistor or even a variable resistor in the hot line from the gauge to dial in the right reading?
Thanks, Larry 1949 3600 completely stock
1949 3600 216 4 speed (completely original)
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | | | | | Joined: Sep 2017 Posts: 19 New Guy | New Guy Joined: Sep 2017 Posts: 19 | Took me a while to find the info.
Empty - 240 ohms; 1/2 - 130 ohms; Full - 33 ohms
Thanks, Larry
| | | | Joined: May 2005 Posts: 8,988 Sir Searchalot | Sir Searchalot Joined: May 2005 Posts: 8,988 | Sending units don't care about voltage. There is NO voltage to a sender. The gauge needs whatever voltage it is designed for. The gauge must also match the ohmage of the sender. Your stock gauge is 6V 30 ohm. The sender must be a 30 ohm for it. But it sounds like you have changed something if you bought a generic sender instead of a stock sender. Can't help you if we don't know what you have. There is a stock 6V gauge, a stock 12V gauge and a stock sender, that works for either gauge, available for 49-53. Your signature says "completely original". 1. 6V or 12V system? 2. Original "new tank"? 3. Original gauges? 4. Why did you buy such a funky sender? | | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | Your fuel gauge is made to work with a 30 ohm sending unit. The sender should provide no resistance when in the empty position (~0 ohms) with progressively increasing resistance as it reaches full resistance (~30 ohms) at the full position. Generic 30 ohm sending units are available from all of the vendors.
| | | | Joined: Sep 2017 Posts: 19 New Guy | New Guy Joined: Sep 2017 Posts: 19 | Ok thanks for the info, I definitely didn't understand this. So the "always full" reading makes perfect sense. I'll replace the sending unit with a 0-30 ohm unit and should be fine.
| | | | Joined: Sep 2017 Posts: 19 New Guy | New Guy Joined: Sep 2017 Posts: 19 | I changed the sending unit to the correct 0-30 ohm sender and made sure it's grounded. It is currently reading 20 ohms and the tank is about 1/3 full (from looking down the hole). However it is still pegging the gas meeting to full. When I shut off the key it will go back to empty. It also sticks after I tune of off and I have to tap on it to return to empty sometimes.
Any ideas? Thanks Larry
