| | | Forums66 Topics128,132 Posts1,056,391 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 18 | Good Morning,
I have a 1941 Chevrolet Howard Cooper fire engine that I believe is based on a 1 1/2 ton chassis, not sure, cannot find the VIN so looking for other numbers. The manual calls for SAE 30 oil, what are others using in these vintage engines?
Thanks Tony | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, Tony,
10w-30 or 10w-40, or 15w30 or 15w40 (I like Rotella T oil)
No need for synthetic oil.
The only concerns about the switch-over from older non-detergent oil to modern detergent oil is that detergent oil keeps more "junk" in circulation (to be removed by an oil filter - if you have one). Non-detergent oils tend to allow "junk" to drop out in the oil pan. There is a possibility that after switching to detergent oil, some of that "junk" will go back into solution.
Some people advise you to remove the oil pan and clean it out (and clean the oil pump "pickup" screen) when switching over from non-detergent to detergent oil. Of course, if you have one, change the oil filter (and, canister) at every oil change. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I use Rotella SAE 30. Not sure of benefits or drawbacks to using a multi weight oil, like Tim suggest, when a straight weight was originally specified and worked fine for years and decades. | | | | | Joined: Feb 2008 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 156 | Tony, that's a really neat truck and a neat story (that you used to be a firefighter in an identical truck). I'm sure you'll have fun working on it and giving your granddaughter a ride! I gave my 5-year old grandson a ride in my '51 half-ton and it scared the holy crap out of him. He's done with that truck, for now.
DJ '51 Chevy 3104 1/2-ton 216
| | | | | Joined: Sep 2013 Posts: 1,365 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,365 | In the summer my 1951 216 gets 15W40 diesel oil, winter it's 5w20. I'd use 15w40 year round except for the fact that when the temps get into the 20's it pours like thick molasses. Not sure how the oil slinger would like that.
Now that said, 15w40 has been in my Dodge Cummins diesel year round for 20 years and at 275k miles, all's still good.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
