1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1240599 10/25/2017 1:46 AM
I
I Offline
How do I get the clutch to stay in place so I can break the bolts loose?
Also since I have it out do I need to change the clutch? It may have been changed before so how do I tell if it's worth putting the same one back?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
Ian Ring #1240600 10/25/2017 2:02 AM
Replace the clutch disc and pressure plate while you have it apart. Peace of mind. Use an air impact wrench to get the old plate off. If you don’t have one you can get a loaner from Autozone or O’Riley’s.🛠
Ian Ring #1240603 10/25/2017 2:18 AM
If you do plan on reusing the pressure plate it is a good idea to loosen all the bolts a little at a time to prevent bending it.
Lock a large screwdriver/pry bar in the starter teeth on the flywheel to prevent it from turning while loosening each bolt.
My Blog
Ian Ring #1240605 10/25/2017 2:46 AM
H Online: Content
Clamp a pair of vise grips on the starter ring gear and let them butt against the edge of the bellhousing to keep the flywheel from turning. Loosen all the bolts a turn or two each, and then loosen them all a little at a time to prevent warping the pressure plate cover. Be careful- - - -the disc can drop suddenly or the pressure plate itself is heavy enough to mash fingers, etc., once all the bolts are removed. One sneaky trick is to insert a clutch plate alignment tool through the plate and into the pilot bushing while removing the bolts.
Ian Ring #1240630 10/25/2017 12:56 PM
If you are going to replace the clutch and pressure plate, replace the pilot and throwout bearing as well.
Rick
1939 Chevrolet Stake Truck
Ian Ring #1240637 10/25/2017 2:04 PM
Ditto on Rick's excellent/logical advice.
Side benefit of buying a complete assembly as a "kit" : you'll be certain the length of the release/throwout bearing matches the height/dome on the pressure plate.
Ian Ring #1240654 10/25/2017 4:46 PM
Check the condition of the flywheel, you might have to have it resurfaced.
Brian
1955.2 3100 Truck
Ian Ring #1240694 10/25/2017 11:39 PM
Discovering that the throwout bearing is bad after installation is one of the most frustrating things I have experienced!
1951 1 Ton Completed
