Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Peggy M, MNSmith, Steelonsteel, 1 invisible), 311 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#12404 05/13/2005 4:18 AM
Tearing down the engine to put on a stand and found the clutch fork stuck on the throw out bearing. With a little persuation,I got it off and the bearing has two ~1/16" worn spots where the fork was pressing on it. The "nubs" on the fork are now "D" shaped (not round). There seemed to be enough travel to the fork that the clutch worked just fine. Do I need to find a new fork? No one seems to list them.
Also how thick is the minimum for a clutch disc?
Thanks for your help.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#12405 05/13/2005 5:32 AM
Now that you have it torn down, you might as well replace it. Just run an ad in the parts wanted section. I'm sure someone will contact you with a good used fork. Cecil........
