1 members (baldeagle),
40
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3 New Guy | | New Guy Joined: Jan 2014 Posts: 3 | First let me say, if I am inadvertently posting this topic in the wrong area, I apologize ahead of time and please move the thread to the appropriate forum; I honestly did not see any other place to post this question.
I was reading elsewhere on the site some information that shed some light on my situation:
"If you were fortunate enough to have a good title for your new purchase, great! It might even have a Vehicle Identification Number (VIN) or "serial number" listed. But while most states titled vehicles by the VIN, some states titled by the engine serial number (found stamped in the block to the left of the distributor), which doesn't have much to do with the body serial number. As most old trucks have had the engine replaced once or twice, your title may not match your engine (if it has been replaced) and your title uses an engine number."
A few years ago I purchased a 47 GMC ACR 700 series that came with a title. However, the identification plate inside the cab did not match the number listed as the VIN number on the title. The ID plate serial number did match the number stamped on the right front frame rail, so it is the correct ID plate. I started looking around and discovered that what had happened at some point in time, the truck was titled by the number on the engine block, as quoted above. There is a small metal tag riveted to the block with the number matching the title VIN number.
Here's my dilemma, I plan to be changing the motor on the truck and I need to make sure there is a valid VIN plate on the truck for law enforcement to check.
Does anyone have legal recommendations on how to remedy this situation?
Thank you in advance.
Alan
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | You have an easy fix since the engine number matches the paper title. Just contact your local DMV and ask then what to do, it's that easy... Mike B  | | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | yes I am in the same situation. I called my insurance company(DMV for you) and explained my vin is the engine ser number but I am getting rid of the engine.... They are issuing me a new VIN that will be attached to the truck at the door post. | | | | | Joined: Jan 2014 Posts: 3 New Guy | | New Guy Joined: Jan 2014 Posts: 3 | Thank you Mike B and Skipdow for your replies. I will do as you have both recommended and contact my DMV for further instructions. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Or one could possibly use the numbers stamped on the right front frame rail-might have to have that verified by a local officer, so tag can never get lost, etc.
Ed
| | | | | Joined: Jan 2014 Posts: 3 New Guy | | New Guy Joined: Jan 2014 Posts: 3 | Thank you Mike, Skip, and Ed. I went to my local tag agency and they directed me to my local DMV just as you gentlemen have; I had to go there anyway since I couldn't find my title and needed a duplicate printed up. They told me where the local DMV in my area was located, so I'll be heading there later this week.
Thank you for your help.
Alan | | |
