1 members (Hotrod Lincoln),
116
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | I am wanting to drill a hole in the steering column and want to know how much room there is between the inner shaft and the outer column .. the colume is 1 1/2 inches out side diameter.
I do not want the screw that I plan on using to touch the inner shaft is my reasoning
Directions are just another man's Opinion
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Just measured mine. 0.75"
| | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | Just measured mine. 0.75" thx Carl ,,
